Celine2020
What should we do when the message [Panel refresh did not finish…] is displayed on SONY OLED TV?
Panel refresh automatically runs after the TV has been used for long periods of time to reduce image retention. If the TV is turned on, the mains lead is unplugged, or the room temperature falls outside of the range between 10 ºC and 40 ºC during the Panel refresh, the process will not be completed and this message will appear.
If Panel refresh started automatically, it will restart when you turn off the TV with the remote control.
If Panel refresh initiated manually, you must select it again.
