Sony's RGB mini LED reaches 4,000 nits and the blooming did not go away
SimonK
Four thousand nits is the number everyone is going to quote, and it is the least interesting thing about this panel. What actually changed is how the light gets made. Instead of a white backlight pushed through colour filters, Sony is driving dedicated red, green and blue mini LEDs behind the LCD. That is the whole pitch. Filters throw light away, and they throw away proportionally more of it the harder you push, which is why so many very bright mini LED sets go pale in exactly the highlights you wanted saturated.
So the wins land where you would expect them to. Bright room performance, colour volume in speculars, that sense of a sunlit scene actually looking sunlit rather than just loud. Sony's processing has never been the weak link and it isn't here either.
The part I keep circling back to is the con list, because it has barely moved across three generations of mini LED. Blooming is still visible. Off axis viewing is still limited. OLED still goes deeper in the dark. Those are liquid crystal problems, not backlight problems. Better emitters make the light better, they don't make the shutter sitting in front of it stop leaking, and no amount of zone count has ever fixed that.
One thing worth knowing before anyone files this under gaming display: 120Hz, four HDMI ports, and only two of them are the 2.1 ones. On a flagship in 2026 that still stings.
If you watch in a bright room this is probably the most convincing LCD anybody has built. If you watch in the dark, has anyone actually sat one next to a current OLED and seen the RGB backlight close the black level gap?
Been saying this for two years. The backlight was never why my old mini LED looked wrong in dark scenes. It's the panel. Nothing you put behind it fixes that.
Off axis is the one that rules it out for me. Wide sofa, three people watching, two of them get washed out colour. OLED solved that a decade ago.
Yusss777
Counterpoint, my room is west facing with two big windows and OLED is basically unwatchable until sunset. Peak brightness isn't a spec sheet flex for me, it's the entire reason to buy.
Emma
Has anyone got measured numbers on the blooming? Still visible covers everything from a faint halo on white credits to full letterbox glow.
Saw one in a shop so take it for what it's worth, but the highlight colour genuinely looked different to the set next to it. Not a subtle difference.
69Shelby1969
Shop demos are worthless. Store mode, a curated loop, and lighting designed to flatter LCD. Come back with a dark room comparison.
SuperM
The RGB emitter thing trickles down in two generations at half the money. Sitting this one out.
