sony Why does everyone recommend SONY TV?
Stefani
SONY, samsung and LG are at the same level in terms of display effect on medium - and high-end TVS, and no one has a clear advantage. SONY OLED TVS also use LG panels. Is SONY TV better at marketing?
Because I saw so many references to SONY's chips, I went to Rtings and truncated the data on the graph below for your reference. The left side is the default of the TV set, and the right side is after manual calibration. More data on the models you can see for yourself at Rtings.
White Balance dE and Color dE less than 3 is good, the lower the better. The difference of numerical value 1 or so ability has significant difference, should be to point to naked eye to see.
The closer the Color Temperature is to 6500 K, the better.
The closer Gamma gets to 2.2, the better.
OLED is LG C8 versus A9F
LG C8
Sony A9F
