XGIMI Horizon S Max vs S Pro – which one to get? And which Vividstorm screen fits?
manishdziva007
Hey everyone,
I’m kind of new to projectors and hoping to set up a home theater soon. I came across the XGIMI Horizon S Max and Horizon S Pro… but I honestly can’t tell what the actual difference is.
From what I understand, they’re both ultra short throw?
Do they use different screen types, or is it just brightness and color accuracy that’s different?
Also, I’ve been looking into Vividstorm screens since I want something rollable.
Should I go for the Vividstorm S PRO or the S ALR? I saw both mentioned online but I’m not sure which one works better with these models.
Would appreciate any beginner-friendly advice 🙏
Thanks!
