On May 21, Xiaomi ecological chain enterprise Lumi released an Aqara smart curtain motor A1, the original price was 499 yuan, which has been pre-sold in JD mall.
Aqara Smart Curtain Motor A1 is a Wi-Fi device, and only need to access the app to achieve many functions such as timer switch, voice control, remote control, etc., without the need to purchase additional gateway equipment.
Has been connected to the Xiaomi AI speaker, and you can control the opening and closing of the curtains and adjust the opening and closing ratio by simply speaking commands to the voice assistant. In addition, customize the opening and closing percentage of curtains through the mobile app, and set multiple modes such as viewing, reading and reading. You can also use different actions to control different opening and closing degrees through other smart devices.
Exclusive customized sound insulation and noise reduction mute rail, smooth and quiet during operation, the operating sound is less than 35 decibels.
With a Bluetooth remote control, you can also control the opening, closing, and stopping of the curtain when the Internet is disconnected. There are also 3 custom scene buttons to realize the curtain opening to 50%, and closing the curtain after half an hour.
In terms of installation, a professional team uniformly trained by Lumi provides one-stop measurement and installation services. It supports a variety of installation environments, and can be customized according to personal preferences and installation environment. Whether it is a new installation or an old curtain renovation, it can be opened double, opened directly Rail L rail, top mounted side mounted, can achieve intelligent curtains.
