Gabe
Xiaomi Mi smart projector 2 Pro VS. Mi smart projector 2 review, which is better?
Many Xiaomi Mi fans are considering whether to choose Mi smart projector 2 Pro or Mi smart projector 2, today let's see their differences:
The 1300 ANSI lumens of the Mi Projector 2pro is higher than the 800 ANSI lumens of the Mi Projector 2.
Both projectors use DLP display technology with a resolution of 1080P, but the DMD display chip is different. Mi 2 Pro's DMD display chip is 0.47 inches, and its picture is native 1080P resolution; while the Mi projector 2 is 0.33 inches chip, although it can also reach its 1080P resolution, but is achieved by display technology.
In addition, the two projectors have different projection ratios, Mi 2 Pro is 1.1:1 and Mi 2 projector is 1.2:1, which means the 2 pro can throw a bigger picture at a shorter distance.
Both are equipped with an Amlogic T972 processor chip, 2GB running memory, and 16GB storage, and use the same MIUI for TV intelligent operating system as Xiaomi TV, which can recommend customized content based on viewing habits.
Both Mi projectors are equipped with two 10W 1.75-inch full-range hi-fi speakers, support for Dolby and DTS decoding, and far-field voice support.
Mi Projector 2 pro supports sensorless autofocus in addition to camera focus thanks to its TOF laser sensor, while Mi Projector 2 only supports the normal autofocus function.
However, the Mi Projector 2 is better in terms of keystone correction, it supports omnidirectional auto keystone correction and ±45° angle adjustment, while the Mi Projector 2 supports vertical auto-correction and only supports ±40°.
| model | Xiaomi Mi projector 2 Pro | Xiaomi Mi projector 2 |
| brightness | 1300 ANSI lumens | 800 ANSI lumens |
| resolution | 1080p | 1080p |
| display technology | DLP | DLP |
| display chip | 0.47" DMD chip | 0.33" DMD chip |
| throw ratio | 1.1:1 | 1.2:1 |
| CPU | Amlogic T972 | Amlogic T972 |
| RAM | 2GB | 2GB |
| ROM | 16GB | 16GB |
| operating system | MIUI tv | MIUI tv |
| speaker | 10W*2 | 10W*2 |
| weight | 3.7kg | 3.1kg |
| keystone correction | Vertical automatic Vertical/horizontal±40° | Omnidirectional automatic correction Vertical/horizontal±45° |
| focusing | Tof non-inductive autofocus | autofocus |
| Dolby sound | Yes | Yes |
| smart voice | far-field voice | far-field voice |
1. Display: 2pro is better in brightness and display chip
2. Configuration: The hardware configuration is basically the same
3. Features: 2 Pro has better focus, Mi projector 2 has better keystone correction
