Gene
Vacuum packaging can extend the shelf life of food and effectively prevent moisture, leakage and odor, but few people will buy a vacuum packer and use it at home. However, if the refrigerator is equipped with a vacuum encapsulation feature, how often do you find it? Based on this idea, Wanki Kim and five other designers have launched a Zero smart refrigerator, which aims to achieve "Zero waste" of food and refrigerator space by using vacuum packaging.
The appearance of Zero smart refrigerator is similar to the common fashion and simple double-door refrigerator. The built-in vacuum sealing machine is located at the bottom of the refrigerator door, which takes up little space and is both hidden and convenient. When packaging food, Zero smart refrigerator will mark the best time to eat it in the mouth of the bag and send it to the smartphone.
On the supporting mobile phone application, users can clearly see the refrigerator inventory, so as to arrange cooking recipes reasonably and effectively avoid repeated purchase. In addition, the app will remind users to eat food that is about to expire as soon as possible and throw away food that has already expired.
In addition, another feature of the Zero smart refrigerator is the full use of space. From the refrigerator door storage space to the cold room, each layer is equipped with a special suspension bracket at the bottom of the shelf, which can be used to use the surplus space between the two layers of brackets to hang up the vacuum sealing bag.
Zero smart refrigerator has realized the combination of food preservation and space utilization, which has solved many people's "pain points" of existing refrigerators.
