A 115-inch TCL in a dedicated room, and the ceiling grid is still white
Felia
Build thread worth a look, and worth arguing with a little. First dedicated room for this guy, 7.1.4, and the front of it is a 115-inch TCL RGB set rather than a projector. Marantz Cinema 30 running everything, Infinity Beta on the floor, 8 inch KEF in the ceiling, a Salamander Chicago 245 holding the gear, Weilanda seats up front and an Ashley double chaise on the second row.
The choice I keep circling back to is the display. A dedicated, light-controlled room used to be the one place a projector was the obvious answer, because you were buying screen size per dollar and you had the darkness to make it pay off. A 115-inch panel in that room says the calculation has flipped, at least for anyone willing to fund the panel. You get black level and output a projector cannot touch, and you give up the last twenty or thirty diagonal inches. In a room that is already treated, I understand the trade completely.
One thing I would push back on. The ceiling tiles were individually painted flat black but the drop ceiling grid was left white, and that grid is a lattice of thin reflective lines sitting directly above a very bright screen. Projector owners obsess over exactly this. With a 115-inch panel pushing serious output the physics has not changed, it just moved. Painting the grid is a cheap afternoon next to everything else that went into that room.
The walls are already on his to-do list so this is less a criticism than a suggestion about order of operations. Has anyone run a big panel in a fully treated room and found the grid actually mattered on screen?
Lily15
The grid point is right. I flat blacked mine and the difference on bright scenes was more than a can of paint has any business making.
JJoker23
115 inches of TCL costs a lot less than it did two years ago, but I would want to know what the wall behind the seating is doing before I spent it.
NetworkingJesus
Infinity Beta with KEF overheads is an odd mix. Timbre matching across the top layer is the thing people notice last and complain about first.
akagi1945
Two rows in a 7.1.4 means the back row is sitting almost on top of the rear surrounds. Curious how he handled delay and level for row two.
Jhjg67
Canless lights on a wifi dimmer are the unsung upgrade in that list. Killing the last 5 percent from the couch beats another sub.
