reality
Dpreview has released the results of its lengthy review of the DJI Mavic AIR 2 drone. The content is quite lengthy, here to give you a summary, give you a brief version.
This new handsets in dpreview Dji Mavic AIR 2 drone review obtained four and a half star high score (out of 5 stars), overall Mavic Air 2 advantage lies in: the volume and weight of the ideal, excellent image/video quality, support 4 k 60 frames per second and 240 frames per second, 1080 p video shooting, 30 minutes of battery life, wind resistance performance is very good, has a good effect of mute, the price is reasonable (value).
The disadvantage is that the remote control is bulky, the link operation is tedious, and there is no top obstacle avoidance (the new one is equipped with front/back/bottom three directions for obstacle avoidance).
Compared with Mavic 2, DJI Mavic AIR 2 drone is smaller in size, portable and flies in a narrow space. According to its advantages, it is believed that newcomers will prefer this new aircraft with more entry-level positioning. However, for professional users with higher requirements, it is better to consider more high-end models. The battery life of the new plane is good, but it doesn't hurt to carry extra batteries when you fly.
