Will the Kodi app run on this Sony X95J TV?
M Markkk_4 Member Dec 22, 2021 #2 Yes, Sony X95J TV supports the Kodi. You can install it from the Google Play Store app of the TV.
5 58129166 Member Dec 22, 2021 #3 yes, it has Google Play, so you can just search for Kodi and install the app
J jojo557 Member Dec 22, 2021 #4 Markkk_4 said: Yes, Sony X95J TV supports the Kodi. You can install it from the Google Play Store app of the TV. Click to expand... good, thx
J jojo557 Member Dec 22, 2021 #5 58129166 said: yes, it has Google Play, so you can just search for Kodi and install the app Click to expand... Got it
