Five factors to pay attention to in choosing smart bracelet?
Abramhham
As wearable devices, smart bracelets were only promoted as decorations at first, but with the miniaturization of batteries, screen display effect and various powerful functions, more and more people choose them. How to choose a suitable smart bracelet? Generally speaking, smart bracelets are mainly used in the following five aspects:
1. check time, metro pass, open the door;
2. Movement monitoring;
3. Sleep quality tracking;
4. Wake up and remind by background vibration;
5. Physical health and accident monitoring.
So what is smart bracelet achieved through? At present, the latest smart bracelet, built-in Bluetooth 4.0 module, has very low power consumption, can maintain a long time standby, built-in corresponding smart sensors, to achieve data collection, some bracelets can also be connected to the Internet by themselves.
Knowing the function of the smart bracelet, what should we pay attention to in the selection for our own needs?
1. In terms of display screen, we give priority to full-color screen, which will improve the beauty of the monochrome screen. The full-color screen can also be replaced with different clock styles, more personalized. There are long bars and ellipses in the display area of the bracelet. You can choose them according to your preference and try to choose regular ones to avoid incomplete information display sometimes.
2. In terms of battery life, try to choose the battery that can stand for 15 days or so. If it is charged once every 2-3 days, it is still troublesome. Now the latest smart bracelet consumes less power, thanks to the reduction of chip energy consumption.
3. Most of the materials of bracelet strap are made of silica gel. Silica gel is comfortable to wear and has softer contact with our skin. Although it is made of the same material, the bracelet with higher price still has better comfort. It is suggested that you first touch the material in the physical store, and then make a decision. You will be more confident.
4. We should also consider the waterproof performance comprehensively. Most of the smart bracelets support the waterproof of life. We mainly look at the waterproof level indicated by it. Now, the smart bracelets and earphones on the market use Pu micro waterproof and breathable membrane, which can generally reach IP67 waterproof level. IP67 means that when the bracelet is not damaged by external force, there will be no dust inside the bracelet, which is no more than 1 meter Deep water can protect the bracelet from damage for 30 minutes.
So IP67 is enough for our daily life. If you are a swimming enthusiast, you are recommended to buy a higher level of waterproof smart bracelet.
Smart bracelet has built-in sensors. According to different user groups, there are some differences in functions. Medical health bracelet will monitor sleep quality, dynamic heart rate, ECG, blood pressure and other parameters. For the elderly bracelet, it will monitor real-time GPS position, accidental falls and alarm, etc. we don't need to choose the wrong functional direction.
Which brand of smart bracelet do you like to use? You can also share it with us!
