Colin J 4576RF64
Wisdom Audio in the United States is the world's famous Hi-end audio manufacturer, which is jointly established by a number of top talents in the audio industry, with strong product development capabilities. In the early years, Wisdom Audio became famous as the "king of speakers" for a pair of giant Infinite Grande Hi-End speakers.
The Wisdom Audio Insight series includes three new models (P2M, P4M and S10) and two colors (highlighted white or bright black). Both P2M and P4M models can play back L / C / R / Sr / LR and top channels. S10 is a series of ultra-thin subwoofer.
Insight series is a small and highly expressive speaker, suitable for installation in the cinema or living room. The Wisdom Audio plane magnetic drive unit (PMD) can provide super strong output, clear and detailed sound.
Wisdom Audio Insight series P2M wall / bookshelf speaker
Wisdom Audio Insight P2M is small in size that can be installed on the wall or bookshelf. It includes a new rotatable planar magnetic drive unit and a robust 5-inch woofer for low distortion, high-resolution output and excellent dynamic range. It can make a 90 degree turn with P4M plane magnetic drive unit (PMD). You can feel the unique and clear sound of Wsdom Audio in the room.
Brief specifications
Frequency response: 70Hz ~ 20KHz
Impedance: 8 Ω
Sensitivity: 87db
Frequency division point: 650hz
Recommended power: 50-200w
Maximum SPL (1m): 110dB
Weight: 6.3kg
Size (H × w × d): 42.2 × 20.5 × 10.5cm
Wisdom Audio Insight series P4M wall / bookshelf speaker
The P4M is equipped with a horizontal flat magnetic drive unit (similar to sage ICS7-a) and two 5 inch bass units. Wisdom Audio Insight series P4M provides embedded wall rack for vertical or horizontal installation, and its box height can also be the best match with the most popular 65 inch TV. There is a hidden line pipeline at the back of the box for convenient collection and wiring. With or without the ultra-low speaker, it can provide a very good sound effect.
Frequency response: 50Hz ~ 20KHz
Impedance: 6 Ω
Sensitivity: 89dB
Maximum SPL (1m): 112dB
Weight: 11.3kg
Size (H × w × d): 84.2 × 20.5 × 10.5cm
Wisdom Audio Insight series S10 independent subwoofer
The S10 (10 inch) passive subwoofer is a versatile device that produces a strong, clean bass from an extremely compact cabinet. The ultra compact design can be changed from stand-alone to down burning or up burning installation, which can be easily hidden under the sofa or cabinet. The stylish S10 is only 4.5 inches (116mm) deep and is designed in a closed box for easy installation. Two S10 subwoofers can be driven by a single SW-1 DSP / amplifier. Luxurious high gloss white or black finish. S10 has no restrictions on placement. It can be installed in a down firing or up firing way. The ultra-thin design is easy to collect and can be placed under a sofa or counter.
Frequency response: 35Hz ~ 80Hz
Impedance: 8 Ω
Sensitivity: 89dB
Recommended amplifier: wisdom SW-1 amplifier-370w / DSP
Maximum SPL (1m): 114dB
Weight: 17.7kg
Size (H × w × d): 15.4 × 39 × 11.6cm
Impedance: 8 Ω
Sensitivity: 87db
Weight: 6.3kg
Impedance: 6 Ω
Sensitivity: 89dB
Weight: 11.3kg
Impedance: 8 Ω
Sensitivity: 89dB
Weight: 17.7kg
