Daniel
M&K Sound was founded in 1973 by Ken Kreisel, dubbed "the father of super bass" and "the father of ducted treble". It is one of the most influential audio brand companies in the world. M&K Sound, a speaker manufacturer with a history of more than 30 years, is one of the world's leading manufacturers of speaker/super bass sound systems. Today I would like to talk about speakers of M&K Sound, because many oscar-winning movies use M&K speakers.
LCR 950 THX Select2 system
1. Model No. : lcr-950
In order to make the 950 series have better performance, M&K Sound at the cost of special equipped with research and design of new flagship model ~ ultra-low weight of exclusive silk vibration membrane + + high heat dissipation, low distortion high sensitivity transmission catheter tweeters, the ultra-low weight, high sensitivity transmission tube high monomer used in M&K each series on the horn, the speakers have excellent high-frequency response! Currently only used on M&K's flagship professional-level active speakers.
Design type: THX Select2 master speaker
Unit structure: 1 1-inch tweeter unit,2 5.25-inch medium woofer units
Technical features:
1) LCR950 USES the latest technology and components from M&K;
2) feather-level silk film coated ball top, with low loss and high sensitivity of the copper-clad aluminum voice coil;
3) the dual 5.25-inch calibration waveforms with directional control can be smoothly connected to the middle and bass;
4) the whole series of antimagnetic low diffracting arcs are processed to strengthen the closed sound box;
5) appearance treatment of high texture fog surface/mirror piano baking paint;
6) high precision phase focusing sound splitting system;
7) THX Select2 authentication;
8) "hidden" magnetic force fixed circular arc porous acoustic horn iron mesh mask;
Frequency response: 80hz-20khz ±3dB
Impedance: 4 ohms
Size (H×W×D) : 40.8×17.8×22.8cm
Weight: 6.9 kg
2. Model no. : SUR95T
SUR95T USES M&K Sound three-way Sound design construction with a 3-inch paper basin unit installed on each side. This three-way sound structure can form a good sense of coherence and encirclement throughout the listening area, allowing the audience to experience excellent knot and encirclement effect. With a small but powerful speaker system, the M&K950 offers excellent sound quality for any room size. The M&K950THX has a modern, stylish visual feel without sacrificing audio performance.
Unit structure: 1 1-inch treble cell at the top of the silk membrane ball, 1 5.25-inch high kinetic energy high magnetic medium bass cell, 2 3-inch medium treble cells
Technical features:
1) THX Select2 authentication;
2) Tripole Surround technology;
3) electronic phase-focused phase-focused frequency divider;
4) fully airtight diffused box;
5) High Frequency Prism System;
Frequency response: 87 hz-20 KHZ ±3dB
Impedance: 4 ohms
Size (H×W×D) : 25.9×17.8×22.1cm
Weight: 4.7 kg
3. Model: 950F Monitor
The 950F Monitor's high and medium sound unit/terminal block USES rust-proof and high-torque steel reinforcing screws, which can make the unit parts closer to the sound ah, producing better airtight performance, reducing sound staining and interference, and restoring rich and pure details. High damping shock absorbers are set inside the speaker to make it have excellent rigidity and shock absorbency, and it still has stable performance of high sound quality in the face of large dynamic and large sound pressure.
Design type: THX Select2 console master speaker
Unit structure: 1 1 "silk membrane ball top treble unit, 2 5.25" high kinetic energy high magnetic medium bass unit
Frequency response: 80 hz-20 KHZ ±3dB
Impedance: 4 ohms
Size (H×W×D) : 120×17.8×21cm
Weight: 20 kg
4. Model no. : MX250 Plus commemorative edition
The mx-250 is equipped with the Dynamic Headroom Maximizer, which is used by the latest generation of M&K's top-level ultra-low sound series, to produce a firm and full ultra-low frequency voice pressure!
The mx-250 is also equipped with the Push Pull double Push Pull technology used by M&K's top ultra-low sound series. The push-pull double single double Push Pull technology can significantly reduce the nonlinear distortion caused by the swing and shift of single paper bowl, reproduce the high dynamic and clean low-frequency details, and improve the ultra-low frequency density and energy output to make the low-frequency more solid and powerful.
Design type: 12 "ultra low sound
Unit structure: 2 12 "special lightweight long stroke high output SUPER FAST bass units
Technical features:
1) 12 "special lightweight long stroke high output SUPER FAST bass monomer;
2) a new 250W high output power monitor amplifier module was developed;
3) fully closed to strengthen the design of vibration resistant box closed sound box, strengthen the sound box air tightness, adapt to the humid environment;
4) new dynamic enhancement circuit;
5) upgrade and optimize power supply stabilization + independent power switch + separated power cord
Frequency response: 20 hz-200 Hz±3dB
Ultra-low sound Dynamic optimization: Dynamic Headroom Maximizer
Power size: 250W
Size (H×W×D) : 59.4×38.7×50.8cm
Weight: 31.9 kg
After looking at the above content, do you have a little understanding of M&K speakers, I hope the above content is helpful to you.
Technical features:
Impedance: 4 ohms
Weight: 6.9 kg
Technical features:
Impedance: 4 ohms
Weight: 4.7 kg
Impedance: 4 ohms
Weight: 20 kg
Technical features:
Power size: 250W
Weight: 31.9 kg
