Hi, does anyone know how much will it cost to fix a Smart TV screen?
G Gamesaa Member Jan 23, 2022 #2 THS-sh said: Hi, does anyone know how much will it cost to fix a Smart TV screen? Click to expand... Repairing the screen alone could cost $200 to $400. You may also have a damaged inverter, backlight or power board. That will increase the repair price. If you own a 4K TV, your TV screen repair cost could be as much as $1,000
R Raok New member Jan 23, 2022 #3 THS-sh said: Hi, does anyone know how much will it cost to fix a Smart TV screen? Click to expand... The cost to fix common problems ranges from $60 to $350, depending on the repair type and the brand of TV being repaired.
G Gamesaa Member Jan 23, 2022 #4 Raok said: The cost to fix common problems ranges from $60 to $350, depending on the repair type and the brand of TV being repaired. Click to expand... Yes, it depends on the problems.
G Gamesaa Member Jan 23, 2022 #5 Raok said: The cost to fix common problems ranges from $60 to $350, depending on the repair type and the brand of TV being repaired. Click to expand... But the screen cost more relatively.
