How to solve LG TV trouble signing in or staying signed in? Many LG TV users may occur these issues.
These types of issues may mean that the app requires an update, or in some cases, the system may need an update.
1. The first thing to try is removing the app, then re-installing it from the Content Store.
(How to uninstall Apps from LG webOS)
2. If that doesn't work, you can try a factory reset on the TV.
3. If the issue is not resolved after trying the two ways above, you need to contact LG support.
