Is ViewSonic R3 Projector Good?
Is ViewSonic R3 good?
The ultra-light and portable ViewSonic R3 has more than 100% rec.709 standard color gamut coverage and 1920x1080 full HD resolution, providing users with full HD, true color restoration visual enjoyment.
modelViewSonic R3
Projection system:0.23" 1080p (1920x1080)
Brightness:600 LED Lumens
Contrast ratio (DCR):400:1
Light source:RGB LED
Light source life: up to 20000 hours
Offset:100%+/-5%
Projection ratio (fixed) :1.2
Trapezoidal correction (automatic) :H:+/-30°, V:+/-40°
Noise (normal mode) :30dB @0.5m
CPU:Amlogic T972 Cortex-A55 64-bit 4 core
Memory:4GB DDR4
Local storage:32GB
Speaker:3W cube
OS version:Android 9.0
input interfacesHdmi2.1:1 (HDCP 2.2)
Audio input (BT4.0) : 1
USB Type-A 2.0: USB Reader*2 (includes A 5V/1.5A power supply)
RJ45: 1
Wi-fi (2.4g 5G 802.11a/B/G/N/AC): 1
output interfacesAudio output (3.5mm) : 1
S/PDIF out: Shared with 3.5mm
Audio output (BT4.0) : 1
HDMI ARC: support
Speaker: 3W Cube X1
The new Viewsonic R3 uses industry leading LED technology to provide a wide range of color gamut with a smaller volume and higher luminous efficiency.
