OnePlus Y1s Pro TV Review: is it good?
Jemma
OnePlus has launched a new TV in India, the OnePlus TV Y1S Pro, featuring a 43-inch 4K resolution panel. So how's the OnePlus Y1Pro TV review? Let's have a look.
OnePlus Y1s Pro TV will feature 24W audio with Dolby Audio and Dolby Atmos, 2GB of RAM and 8GB of storage. The spotlight attribute of the OnePlus Y1s Pro TV is the 4K (3840 x 2160 pixels) panel - an upgrade from HD and FullHD panels. The Y1S Pro will only be available in a single size of 43 inches.
The OnePlus Y1s Pro TV has very narrow side and top bezels and a thick bottom bezel with the OnePlus logo. The remote appears to have shortcut buttons for Netflix, Disney+ Hotstar, Prime Video, Google Assistant, and OnePlus buttons. The rest of its controls are pretty standard: a d-dab with a center button, back button, home button, volume up and down, and what looks like a menu button or an input selection button in the upper right corner.
Obviously, the OnePlus TV Y1S Pro is a smart TV. Oddly it will run Android TV 10 instead of Android TV 11 which the TV Y1S and Y1S Edge have. Even so, it should support Google Chromecast, Miracast and OnePlus Connect 2.0, Google Assistant and Alexa. There may be a microphone inside the remote. The OnePlus TV Y1S Pro has 2GB of RAM and 8GB of internal storage, a stereo 24W speaker setup, and it comes with Dolby Audio and Dolby Atmos to external soundbars and speakers. Connectivity on the OnePlus TV Y1S Pro includes three HDMI inputs, two USB ports, and dual-band Wi-Fi.
