Overheating issue may cause damage to your TV box
Stefani
For any electrical equipment, cooling must be considered to ensure that the equipment works well, and the TV box is no exception. As the weather gets hotter, the problem of TV boxes overheating is only going to get worse. In this issue, HDP market research is going to talk to you about the cooling of TV boxes.
Heating source:
The heat source of TV box is mainly from the motherboard, among which the heat energy of CPU and WIFI module is the highest.
On the one hand, because the TV box generally adopts the chip scheme combining CPU and GPU, the box will generate a lot of heat when working, especially in 4K decoding and games, the TV box will heat up sharply and we can feel it by touching it. On the other hand, the WiFi module needs to keep signal coverage and data transmission at all times, which will also generate a lot of heat. However, compared with the CPU module, the heating curve is much smoother, and some of the better optimized high-end TV box WiFi modules do not even heat up significantly.
Overheating hazards:
Because the chip module is the main heating components of the TV box, once overheating occurs, the chip, the system bear the brunt. Users will obviously feel the system reaction slow, stuck, blue screen, flash back; The overheated WiFi module is manifested in the decrease of network transmission speed and obvious network delay. In addition, a long time in the overheating of the state of the TV box, motherboard aging speed will be faster.
