Gabe
Model | realme Smart TV 80cm(50”) | realme Smart TV 80cm(43”) |
Screen type | SLED | SLED |
screen size | 55"inch | 43“inch |
Screen resolution | 3840 x 2160 | 3840 x 2160 |
Display colors | 1.07G Colors | 1.07G Colors |
Screen ratio | 16:09 | 16:09 |
Screen viewing angle | 178° | 178° |
Picture processor | MediaTek 64-bit Quad-core Processor | MediaTek 64-bit Quad-core Processor |
Picture technology | Chroma Boost | Chroma Boost |
Sound output | 24W | 24W |
Speaker configuration | 4 units | 4 units |
Dolby audio | Yes | Yes |
Operating system | Android TV | Android TV |
Built-in APP | Netflix, YouTube, Prime Video, etc. | Netflix, YouTube, Prime Video, etc. |
Software upgrade | OTA upgrade | OTA upgrade |
Voice assistant | Google Assistant | Google Assistant |
Wifi | 2.4GHz/5GHz | 2.4GHz/5GHz |
Bluetooth | 5.0 | 5.0 |
Infrared | Support | Support |
Bluetooth file transfer | Support | Support |
Bluetooth music | Support | Support |
Remote control | Bluetooth & Infrared | Bluetooth & Infrared |
HDMI | three | three |
AV | one | one |
Tuner | two | two |
USB | two | two |
LAN | one | one |
Audio out | COAX | COAX |
Size | 111x7.5x64.7cm(Without stand) 200 × 200mm | 96x 7.6 x 56.3cm (Without stand) 200 × 200mm |
Weight | 13.1kg (Gross Weight) 9.2kg (Net Weight) | 9.5kg (Gross Weight) 6.5kg (Net Weight) |
Voltage | 90V-240V 50HZ | 90V-240V 50HZ |
Operating temperature | -40~60℃ | -40~60℃ |
Passive standby power | ≤0.50W | ≤0.50W |
Humidity | < 80% | < 80% |
Power Consumption | 120W | 100W |
Relative humidity | <90% | <90% |
Storage temperature | -20~60℃ | -20~60℃ |
