Nadia
The Xiaomi Redmi Smart TV X 2022, which was previously announced as the "must-have entry game TV for young people", was released a few days ago. As another entry-level premium TV, the OPPO TV K9 is also very popular. So what are their difference?
The first difference between Redmi Smart TV X2022 and OPPO TV K9 lies in the start-up ads. OPPO TV K9 continues to start up without ads, and enters the main interface directly; while Redmi Smart TV X2022 still has ads, and the ad time is about 30S.
Both TVs have metal bezels, which are more textured than plastic bodies, and both are full-screen designs. The difference is that the Redmi Smart TV X2022 will have a higher screen-to-body ratio, reaching 98.2%, while the OPPO TV K9 has a 95% screen-to-body ratio. In comparison, with the same 65" screen playing the same video, the Redmi Smart TV X2022 has a more open field of view and less restrictive bezels.
The wide color gamut of Redmi Smart TV X2022 is higher. When both are DCI-P3 color gamut standard, while Redmi has 94% color gamut value, higher than OPPO TV K9, but there is no visual impact, the difference is not too big. At the same time, the Redmi Smart TV X2022 has a higher peak brightness, up to 450nits brightness, while the OPPO TV K9 has a maximum of 300nits. The higher brightness means that the screen has a more pronounced contrast between light and dark, and does not have the problem of white light all around.
The screen refresh rate is also different, Redmi Smart TV X2022 has dual 120Hz ultra-high refresh, any picture can be a perfect transition, there will be no screen lag and blurred problem. OPPO TV K9 maximum refresh rate is 60Hz, there's no problem in daily use, but if you want to have a better live viewing or gaming experience, Redmi Smart TV X2022 is definitely better.
Redmi Smart TV X2022 has bigger storage, equipped with a 3 + 32GB memory combination. 3GB memory and quad-core A73 processor match perfectly which can make the TV response faster. As an entry model, this configuration is really high. OPPO TV K9 is 2 + 16GB memory, which is fine for daily use, but if you install more applications, your TV will be slow.
In addition, Redmi Smart TV X2022 can also support VRR variable refresh rate, which can add repair frames according to the real-time screen, which can repair dropped frames in time to prevent screen tearing and further upgrade the gaming experience; while OPPO TV K9 does not support VRR variable refresh rate.
Difference 1: Startup with or without ads
Difference 2: TV appearance difference
Difference 3: the picture quality parameters are different
Difference 4: Hardware Configuration
