This article will compare Samsung QN90B vs Sony A80K TVs. The Samsung QN90B and Sony A80K use different panel technologies and therefore have different characteristics. Samsung's QLED combines quantum dots with Mini LED to provide a brighter, better black-level image. The Sony A80K offers the perfect contrast and premium image that all OLED TVs have.
Samsung QN90B vs Sony A80K: Overall Comparison
Samsung QN90B QLED TV Quick Review
The Samsung QN90B features Samsung's QLED technology, which combines Mini LED with quantum dot technology. Because more and smaller LEDs can fit on the screen, it provides more and more precise local light control, which improves the brightness and contrast of the TV. The Samsung Neo Quantum Processor 4K further upgrades the quality of the TV image to provide an outstanding picture experience.
Sony A80K OLED TV Quick Review
The Sony A80K is Sony's mid-range OLED TV model for 2022, a successor to last year's A80J. Its OLED panel offers impressive deep blacks and perfect contrast. It has a wide viewing angle for wide seating arrangements. The TV has very low input latency and also supports variable refresh rate and HDMI 2.1, so it's also great for gaming.
Samsung QN90B vs Sony A80K: Picture Quality
The Samsung QN90B is impressively bright, with its excellent high peak brightness enough to combat glare in bright rooms. In some of the larger bright scenes, its automatic brightness limiter reduces its brightness, which may occasionally distract you.
The QN90B's low native contrast ratio is due to Samsung's addition of a wide viewing angle layer to the TV screen, which improves the TV's viewing angle rather than the narrow viewing angle of a regular LED TV. But at the same time, it also reduces the contrast ratio. However, the TV's local dimming function can effectively improve the TV's contrast ratio and render excellent deep blacks in dark scenes.
Like other OLED TVs, the Sony A80K has a perfect contrast ratio for uniform deep blacks. Thanks to Sony's Cognitive Processor XR, the image is adjusted to become more realistic and capable of rendering accurate colors.
Unfortunately, the Sony A80K is not bright enough and it struggles to resist a lot of glare in rooms with a lot of ambient light or very bright. The OLED panel will also give you the wide viewing angles you expect, and you'll be able to get accurate and unfaded images even when off-center on the screen.
Samsung QN90B vs Sony A80K: Design
The Samsung QN90B has a simple and stylish design with a very thin bezel and stands that are well-made. The centrally located metal stand is small enough that the TV can be placed on a narrow tabletop, but the TV can wobble a bit.
The back of the TV is very clean and the plastic with etched lines is high quality. The back of the panel provides access to cable management. As an LED TV, the QN90B is thin enough that you can wall mount it and the TV is able to sit flush with the wall.
Sony continues its minimalist design with the A80K, with extremely thin bezels that blend well into the environment. Sony's One Slate design gives the screen a monolithic look that works well. The narrow silver stand supports the screen well, and you can choose from three different positions. The wide and narrow positions are suitable for different sizes of furniture, and you can also raise the TV in the soundbar position to place the soundbar.
Sony provides covers on the back of the TV for cable management, making it difficult to access the inputs when you wall mount the TV.
Samsung QN90B vs Sony A80K: System
The Samsung QN90B comes with Tizen 6.5 version 2022, a new interface that has been redesigned to fill the entire screen and is capable of providing more personalized recommendations. Samsung has the usual streaming services built in, and of course, you can download a large number of apps and streaming services from Samsung's app store.
The QN90B is compatible with Google Duo and can support features such as video calling.
Sony A80K comes with Google TV 10, a smart platform that runs smoothly and is easy to operate. You can log in to your Google account for personalized recommendations, and the Google App Store offers a large selection of apps and streaming services. You can also cast content from your phone to your TV via the TV's built-in Google Chromecast.
Samsung QN90B vs Sony A80K: Inputs
The Samsung QN90B TV has a very low input latency for smooth and responsive motion. It supports 4K 120Hz and offers four HDMI 2.1 ports. If you have multiple high-bandwidth devices, it can meet your need to connect multiple devices at the same time.
The TV supports HDR10+, but unfortunately, it does not support Dolby Vision like other Samsung TVs. It supports VRR, FreeSync, and G-Sync for very good compatibility with Xbox and PS5.
The Sony A80K supports up to 4K 120Hz with low input latency in gaming mode, providing a responsive gaming experience. Only ports 3 and 4 of the TV's four HDMI ports support HDMI 2.1, so if you have multiple high-bandwidth devices, you will have to connect HDMI 2.0.
It supports ALLM and VRR and is compatible with PS5 and Xbox.
Samsung QN90B vs Sony A80K: Summary
Samsung QN90B and Sony A80K are both excellent 4K TVs but have different advantages and disadvantages due to their different panel technologies, and you need to choose according to your needs.
The Samsung QN90B delivers amazing brightness and is capable of presenting quality images in bright environments, while the local dimming feature improves contrast and is also suitable for viewing in the dark. Its rich connectivity and gaming features will please gamers.
The Sony A80K meets our expectations of an OLED, offering perfect contrast and deep blacks, making it a great choice for watching movies in dark rooms. But it's not bright enough to resist glare in very bright rooms. In addition, it has good gaming capabilities, but only two HDMI 2.1 ports.
The OLED panel provides a wider viewing angle, so if you're looking to buy an OLED TV, you can also check out the Samsung QN90B vs LG G1, which is also an excellent OLED TV.
