Xmint
With Smart Home Hub, you no longer have to worry about whether you have locked the door after going out; the air conditioner will automatically turn on and adjust the indoor temperature before returning home. SamSung SmartThings and Wink Hub 2 are highly recommended in the field of smart home hub. Which one is better? Let's check the SamSung SmartThings and Wink Hub 2 in detail:
SamSung SmartThings Hub
SamSung SmartThings Hub is currently a popular hub, mainly because it is compatible with the connection protocols of most smart products currently on the market, and SmartThings hub can be used with many third-party smart products (although the official does not temporarily support Nest products). The second generation of SamSung SmartThings Hub adds battery backup power.
As long as the SamSung SmartThings Hub is connected to the router, the SamSung SmartThings Hub can control the connected smart products through the network, and then SamSung SmartThings Hub can install the app on the mobile phone (support iOS / Android / Windows phone) to easily carry out various Kinds of settings and SamSung SmartThings Hub remote control. It can also be used with Amazon Echo or Google Home to add more cool voice control functions.
Wink Hub 2
Wink Hub 2 is also one of the more popular smart hubs on the market in the United States. Wink Hub 2 is also compatible with various mainstream connection protocols. Wink Hub 2 can use more smart products than other hubs and has simple settings. The appearance of the second-generation Wink Hub 2 is very simple and stylish, and Wink Hub 2 has more compatible protocols than the first generation. Wink Hub 2 adds a 5GHz WiFi connection, an Ethernet interface, and memory. It is also easier to set up. At the same time, Wink Hub 2 can also be connected to Amazon Echo and Google Home for voice control.
However, compared to SamSung SmartThings Hub, the functional design in the Wink Hub 2 app will be simpler, and the advanced functions of some smart products may not be fully exerted, which makes Wink Hub 2 not enough for advanced users.
Wink Hub 2
