radiogaga
Tencent's Beijing headquarters building, Known as "Asia's largest single office building", is not only has a spacious and comfortable office environment, but also a professional studio production center. In the high-end entertaiment room equipped with professional equipment such as Sony 4K laser SXRD projector VPL-GTZ270 and panoramic sound system, allowing creators and managers to use industry-leading equipments.
The details of the audiovisual room are very professional, whether it is sound-absorbing walls, audio production equipment, multi-channel monitor speakers, panoramic sound systems, audio and video players, theater sofas, etc., let people feel that there are both recording / tuning room and film review The function of the room can not only complete the audio production at the concert hall level, but also present a large screen at the cinema level.
It is Sony VPL-GTZ270 that is in the central of the audio-visual room. It integrates many "black technologies" into one and creates a brilliant picture in the industry. The person in charge of the audio-visual room said that the quality of Sony products has always been trustworthy. Here, we want to build a cinema-level audio and video system. Sony is the priority brand. After a comprehensive investigation, Sony VPL-GTZ270 relies on true 4K resolution and high-quality images. The advantages stand out. Now as the review room plays important video content frequently, the overall performance of Sony VPL-GTZ270 is satisfactory.
Advanced SXRD reflective LCD display is Sony's unique core tech, providing 4096 x 2160 native 4K resolution, no artificial pixel enhancement, pixel spacing is only 0.2 microns, every detail is very clear and natural, no jagged edges or visible Pixels. It also has a professional-grade BT.2020 wide color gamut; the advanced optical engine can finely display the details of dark scenes, achieving a high contrast ratio of 20,000:1.
With the help of real creative enhancement and support for HDR (high dynamic range) and high frame rate, Sony VPL-GTZ270 can fully display the quality of 4K content. charm. High-speed 4K 120Hz signal processor and three black frame insertion modes can reduce motion blur and smear; low transmission delay improves the effect of sports scenes.
For the audio-visual room, stable operation is of great significance. The VPL-GTZ270 uses a high-efficiency laser light source with a lifespan of 20,000 hours and up to 40,000 hours in constant brightness mode. Since there is no need to replace the lamp, maintenance work is almost zero. In addition, the lens, light source and optical components are sealed to resist dust attack, achieve reliable long-term operation, and prevent malfunctions from affecting work.
In order to ensure the review work, the projector needs to be in a high-quality state at all times. Sony VPL-GTZ270 has an automatic calibration function, adjusts RGB color levels, and achieves consistent image quality over a long period of time. It is compatible with various audio-visual room automation systems, adapts to central control and professional software, and can be easily applied in various scenarios, easily and efficiently. In addition, Sony VPL-GTZ270 uses a low-noise fan and water cooling system with unidirectional airflow, 35db low noise, quiet operation and reduced interference.
In recent years, as enterprise users have paid more and more attention to visual content and audio-visual experience, high-end audiovisual rooms have become increasingly popular in professional venues, artistic creativity, industrial design, virtual simulation, multi-function halls, etc., and a large number of high-quality video. The high-end audiovisual room of the performance group of Tencent Beijing Headquarters Building is a representative case. I believe that with our outstanding strength, we will see more creative audio and video spaces created by Sony VPL-GTZ270 in the future.
