loughborough
I already set up an internet connection netween Philips 42PFL6805H/12 and my router, but it does not work. What should I do? Here is the solution for this issue on Philips 42PFL6805H/12, 52PFL8605H/12 and 46PFL9705H/12:
First of all, check the IP adress that you are using, make sure the IP adress is correct:
pressing [Home] -> [Setup] -> [Installation] -> [Network] -> [View network settings] -> [IP address].
if the number displays as "000.000.000.000", it indicates that the Internet connection between your TV and router/modem is not working.
How to fix it?
If you use a wireless Internet connection, check if your TV is connected to a wireless network by pressing [Home] -> [Setup] -> [Installation] -> [Network] -> [View wireless settings].
If the Status is Not connected, your TV might be too far away from your wireless router. You can lower the distance between your TV and wireless router or set up a wired connection as described in your User Manual to solve the issue. If your TV is within reach of your wireless router but still does not connect to your wireless router (Status is Not connected), try to connect another Internet device, e.g. a laptop, to your wireless router.
If you can access the Internet with this device, contact your Philips helpdesk.
If you cannot access the Internet with this device, contact the helpdesk of your Internet provider/modem/router supplier.
If Status is Connected, then the Internet connection between your wall outlet and router/modem is not working. Check all connections from your wall outlet and modem to the router and restart the modem and router. If the problem persists, contact the helpdesk of your Internet provider/modem/router supplier.
If you use a wired Internet connection or if you use a router, check all cables between your TV, router, modem and wall outlet. Restart your modem and router. If you only use a modem, check all cables between the wall outlet, modem and your TV, and restart your modem.
If the problem persists, try to connect another Internet device, e.g. a laptop, to your router/modem.
How to fix it?
