Valerion is pushing its anti-rainbow fix to the whole premium lineup
Michaelwu
Valerion has pushed its Anti-RBE processing out to the rest of the premium long-throw range, so VisionMaster Pro, Pro 2, StreamMaster Plus and Plus 2 all get it at no cost. It needs the latest Android software plus a DLP software upgrade underneath, so it is not a one-tap thing. The feature started on the VisionMaster Max, and the company line is that it raises the refresh rate and blends the colour sequences fast enough that your eye stops resolving the flashes.
The number that caught me in the announcement is the split they quote: around 60% of viewers report little or no sensitivity, and the remaining 40% find rainbows distracting. That is a manufacturer figure and I would treat it as one, but the shape of it matches what happens in a real room. One person watches a whole hockey broadcast and never mentions anything, the next cannot stop seeing red and green fringes every time the puck crosses dark ice. Single-chip DLP has carried this since the colour wheel days, and triple-laser designs already cut it down a lot. Their own CTO says exactly that in the release, which makes this a refinement rather than a rescue.
What the notes do not say is what it costs. Raising refresh and adding processing usually shows up somewhere, whether that is input lag, motion artefacts or peak output, and nothing in the release addresses any of it. Free is free and I would take it. I would also run a scene I know well before and after rather than trusting the toggle.
If you own one of these and have already updated, has anyone measured lag or put a meter on white either side of it?
horizon936
That 40% figure is doing a lot of work. In my house my partner sees rainbows constantly and I never do, on the same projector, in the same seat.
Mia
A firmware that raises refresh rate usually gives something back somewhere else. I want lag numbers before and after, not release notes.
Hellopi314
Funny that the CTO points out triple-laser was already less prone to it. Reads like they are fixing a problem their own marketing said they did not have.
PLAY GAME
No complaints about getting it free on hardware I already bought. Wish more brands did this instead of saving it for next year's model.
lamjs
Does the DLP software part need a service tool or is it in the normal update flow? That is the bit that would put me off doing it myself.
