According to the following three points, you can check your XGIMI projector. Currently, the projector autofocus function is limited
1. The distance between the projector and the wall should not be too far. It is recommended to use autofocus within 3 meters for better effect.
2. If the autofocus is still not clear at the right distance, restart the projector to see if the focus is clear.
3. If it is still not clear, you can go to Settings - Focus Settings or the side button to choose manual focus, adjust the appropriate sharpness
