Fengmi S5 vs XGIMI NEW Z6X: What's the difference?
Fengmi S5 and XGIMI NEWZ6X are projectors with similar prices. So what is the difference between the two projectors? Let's compare the parameters to see what is the difference between Fengmi S5 and XGIMI NEWZ6X, and which projector is more worth buying.
1. Fengmi S5 vs XGIMI NEW Z6X: Optical parameter
Fengmi S5 and XGIMI NEWZ6X use different light sources in terms of projection light sources. The Fengmi S5 uses a laser light source, which is better than the XGIMI NEWZ6X that uses an LED light source.
In addition, the actual brightness of Fengmi S5 is higher than that of XGIMI NEWZ6X, reaching 1100ANSI lumens, and it supports projecting a brighter picture. As for the resolution, the standard resolution of the two projectors has reached 1080P, and the picture is clear.
2. Fengmi S5 vs XGIMI NEW Z6X: system parameters
In terms of processing chip, Fengmi S5 is equipped with Amlogic T982 processing chip, compared with MSTAR6A848 processing chip carried by XGIMI NEWZ6X, it has stronger computing power and supports fast decoding of video image signals.
As for storage space, both projectors use a 2G+16G storage combination, both of which support online viewing of movies and TV series and download and install third-party application software.
3. Fengmi S5 vs XGIMI NEW Z6X: projection parameters
In terms of voice functions, both Fengmi S5 and XGIMI NEWZ6X are equipped with intelligent voice assistants. The voice function of Fengmi S5 is more powerful. It supports far-field voice function, and users only need to use voice commands to wake up the voice assistant. In addition, Fengmi S5 has lower latency than XGIMI NEWZ6X, providing users with convenient games.
Fengmi S5 vs XGIMI NEW Z6X: Which one is worth buying?
In summary, through the comparison of the parameters of Fengmi S5 and XGIMI NEWZ6X, it can be found that Fengmi S5 is better in use as a whole, so I personally think Fengmi S5 is more worth buying.
You may also want to read more about:
Fengmi S5 projector specs review, 1080p and 1100 lumens
XGIMI NEW Z6X Projector
