Xiaomi's 360Hz claim on the S Pro 2027 only holds in competitive mode
Trollatopoulous
If you see the 360Hz headline on the new S Pro 2027 and start thinking about a console or a PC in the living room, read the second paragraph first. Xiaomi says 360Hz can only be activated in competitive mode, and in 4K the panel sits at 120Hz with MEMC. That is not a scandal, everything hitting these numbers drops resolution to get there, but the marketing does not lead with it and somebody here is going to buy one expecting 4K360.
The rest of the sheet is genuinely aggressive. Four models at 65, 75, 85 and 98 inches, up to 4,860 zones on the top one against 3,864 on last year's, 5,000 nits peak claimed, 100 percent BT.2020, and because these are RGB mini LED the zones adjust colour balance rather than only brightness. Four HDMI 2.1, VRR and FreeSync Premium Pro, a quad-core A73 with Xiaomi's XM900 image chip, 4GB of RAM, and a 130W 2.1.2 speaker array.
No pricing yet, which is the whole story for anyone outside China, and the full launch is September in China with a separate Supreme line still unannounced. Zone counts and nit ratings pulled from a Chinese launch deck are also the least reliable numbers in this hobby until somebody puts a meter on one.
The jump from 3,864 to 4,860 zones is about 25 percent more dimming resolution. On a 98-inch screen in a dark room, does anyone here think you would actually see that, or is the RGB colour control the part doing the real work?
58129166
5,000 nits peak. On a 2 percent window for half a second, presumably. Wake me when someone measures a 10 percent sustained figure.
Pikak
The RGB backlight is the actual news and it is getting buried under a refresh rate nobody can feed. Colour volume at high brightness is where mini LED has always lost to OLED.
Emma
4GB of RAM on a set that will cost what these cost. Three years in, that is what makes the TV feel old, not the panel.
Elena
Competitive mode on these usually means 1080p plus a processing bypass that also kills the tone mapping. Worth checking before anyone gets excited.
Honestly 4K120 with VRR and FreeSync Premium Pro is already more than my consoles can saturate. 360Hz is a number for the box, not the room.
Daniel
98 inch is the size that interests me and it is also where zone bloom gets most obvious. More zones is genuinely welcome there.
