Christie 4K1000-KS at CEDIA: 10,000 ISO lumens for $14,461
Tomy
The number I keep chewing on from the Paragons of Home Cinema Episode II lineup is 10,000 ISO lumens. That is the Christie 4K1000-KS getting its CEDIA debut in Sound Room 7 - single-chip DLP, 0.8-inch HEP DMD, a 1.25-2.0:1 zoom, $14,461. If you have spent the last decade thinking in the 1,500 to 3,000 lumen bracket like most of us, that is not a brighter version of what you own, it is a different lighting budget entirely.
The rest of the room explains why they need it. Stewart is putting up VistaScope Evo, a two-way vertical masking system using Harmony G3 acoustically transparent woven material, going out to 188 inches diagonal at 2.39:1. Woven AT screens cost you light, masking means you are filling that whole width with scope content, and suddenly ten thousand lumens is a spec rather than a flex. Same reason commercial rooms have always been rated the way they are.
The part I am less sold on is Lumagen debuting the ArtisaN 8K Ready at $11,495, with 4K120 and 8K processing as a $2,500 upgrade later. Eight inputs, two outputs, dynamic tone mapping, a 3ms game mode - fine, that is the day job and Lumagen is good at it. But paying twenty-five hundred down the line to process 8K sources that basically do not exist in this format is buying a promise.
For anyone here running acoustically transparent material on a wide scope screen: what did the weave actually cost you in measured brightness? I have seen guesses from 10 percent to a third and nobody ever posts a number.
Jemma
Ten percent is optimistic for woven. Mine measured closer to 18 on a white AT weave, and that was before I put three speakers behind it soaking up whatever bounces back.
Happy7User
Two-way vertical masking on a 188in scope screen is the bit I want to see in person. Most masking systems I have watched in showrooms are noisy and slow enough to kill the mood.
fosterzar
The 8K upgrade path is how these companies keep the resale story alive. Nobody is processing 8K at home in 2026 and they know it.
