How to Mount an Outdoor TV on Brick (No-Damage Method)
olena
TL;DR:
Mounting an outdoor TV on brick is absolutely do-able and is often the best wall type for long-term outdoor installations — brick handles weight, weatherproofs well, and the holes can be patched invisibly with mortar if you ever remove the TV. The key: drill into the brick face (not the mortar joints), use heavy-duty masonry anchors rated for 100+ lbs, and seal every penetration with silicone caulk. This guide covers the 9 steps start-to-finish for a **ByteFree BF-55ODTV ($1,499)** or equivalent 55-inch outdoor TV.
Quick decisions before you start​
Brick face vs mortar joint?​
Drill into the brick face, not the mortar joint.
Brick is denser, harder, and holds concrete anchors at 100–200+ lbs rated load per anchor.
Mortar is softer, crumbles more easily, and is only rated for 40–80 lbs per anchor.
If you want to remove the TV later, brick holes can be patched with matching color mortar that's virtually invisible. Mortar joint holes are more obvious.
Brick type​
Brick type​
Drilling difficulty​
Notes​
Clay brick (red, most common U.S.)MediumEasy with masonry bit
Concrete brick (gray, modern builds)Medium-HardDenser; use carbide bit
Painted brickMediumPaint chips around hole — have touch-up paint
Brick veneer (thin layer over framing)Easy — but use short anchorsDon't penetrate framing behind
Historic/old brickHardBrittle; may crack under drilling
Tools you need​
Required:
Hammer drill (not a regular drill — brick is too hard for standard drill)
1/4″ or 5/16″ masonry drill bit (size depends on anchor)
Concrete anchors rated 100+ lbs (wedge anchors or sleeve anchors)
Socket wrench + socket matching anchor bolt size
Level
Tape measure
Silicone caulk (clear, outdoor-rated)
Outdoor-rated TV mount with VESA 400×400 (for BF-55ODTV and most 55″ outdoor TVs)
Pencil or painter's tape for marking
Recommended:
Stud finder (to confirm you're drilling into solid brick, not a hollow area)
Wet-dry shop vac (dust control from drilling)
Second person (TV mounting requires 2 hands)
Step 1: Verify wall load capacity​
Confirm the brick can hold TV weight.
Solid brick walls (1 brick thick): 80+ lbs per anchor, typically 4 anchors = 320 lbs capacity — exceeds any 55″ TV
Brick veneer over framing: 40–60 lbs per anchor in the veneer; may need to drill into the framing for load
Older mortar (pre-1970s): may be weaker; load-test one anchor before full install
Hollow brick / clay masonry units: can support TVs but require specific anchor types
For reference, common 55″ outdoor TV weights:
**BF-55ODTV**: ~58 lbs
Sylvox Deck Pro 2.0: 54.5 lbs
SunBrite Veranda 3: 47 lbs
With 4 anchors rated 100+ lbs each, any solid brick wall handles these easily.
Step 2: Mark anchor positions on brick face​
Important: position anchors on the brick face, not mortar joints. This means:
Hold the mount against the wall, level it
Position so all 4 (or more, depending on mount) anchor holes fall within brick faces
Mark each hole position with pencil
You may need to shift the mount left/right by 1–2 inches to align anchor holes with brick faces instead of joints. That's fine.
Verify:
Level across horizontally
Centered vertically at your target TV height
Clearance around for cable access
No obstructions (windows, doors, pipes)
Step 3: Drill pilot holes​
Using a hammer drill (regular drills can't handle brick):
Start with smaller bit (1/8″ or 3/16″) as pilot — prevents walking
Switch to sized anchor bit (usually 1/4″ or 5/16″)
Drill to depth slightly deeper than anchor length (1/8″ extra for debris)
Use a vacuum or brush to clear dust from each hole
Always wear safety glasses — brick shards are sharp
If the bit gets stuck:
Pull back and let the hammer action break up material
Use shorter drilling passes
If you hit a void (sudden loss of resistance):
Stop immediately. You're in a hollow area or mortar — abandon that hole and find a new solid brick position.
Step 4: Install concrete anchors​
Anchor types for outdoor TV installation:
Wedge anchors (best for heavy TVs)​
Stainless steel body
Expands against the concrete wall as bolt tightens
Rated 200+ lbs per anchor
Highest load capacity
Sleeve anchors (mid-tier)​
Steel sleeve with bolt
Expands outward when tightened
Rated 100–150 lbs per anchor
Easier to install than wedge
Toggle bolts (lightweight)​
Not recommended for heavy TVs — only 60–80 lbs rated
Good for very thin brick veneer where wedge/sleeve won't work
For BF-55ODTV and equivalent 55″ TVs: use sleeve anchors minimum, wedge anchors preferred.
Installation:
Insert anchor into pilot hole
Tap with hammer until flush
Screw bolt into anchor
Tighten until snug (don't overtighten — can crush brick around anchor)
Step 5: Seal penetration before attaching mount​
Critical step: apply silicone caulk around each anchor hole before bolting the mount plate on.
This creates a weatherproof seal that prevents water from migrating through the hole into the brick wall (where it can cause long-term moisture issues behind the brick).
Apply a small bead of clear outdoor-rated silicone around the anchor
Press mount plate against wall — silicone squeezes out around anchor
Wipe excess flush with the wall surface
Step 6: Bolt mount plate to anchors​
Hold mount plate over anchors
Thread bolt through mount plate into anchor
Repeat for all anchors
Tighten with socket wrench — firm but don't overtighten (1/4 turn past snug is enough)
Verify level — mount plate should still be level horizontally
Step 7: Run cables through brick​
Two approaches:
Option A: Through the brick wall (cleanest)​
Use a long masonry bit to drill through the wall where cables will enter the inside
Wear safety glasses — dust control essential
Run power, ethernet, HDMI through the hole
Seal the hole with silicone around cables to prevent water migration
Option B: Along the wall surface in conduit​
Run cables in outdoor-rated conduit along the wall
Conduit exits up to an outdoor power outlet or through a wall somewhere hidden
More common for rental installations or walls where drilling isn't allowed
Either approach works. Option A is more aesthetic but requires more confidence in drilling through brick.
Step 8: Attach TV to mount​
Two people minimum for 55″ TVs:
Attach TV-side plates to VESA holes on back of TV (usually included with outdoor mount)
Lift TV (1 person per side)
Engage TV-side plates into wall-side mount bracket
Lock engagement mechanism (varies by mount)
Perform light push/pull test — should not move
For the **BF-55ODTV** at 58 lbs, 2 adults can comfortably lift and position. One-person lifts risk dropping and cracking either the TV or your foot.
Step 9: Finalize and test​
Connect power, ethernet, HDMI
Power on and test Netflix/streaming
Verify remote control works
Test at different times of day for sun exposure
Apply final silicone beads around any exposed penetrations
Document the installation — photograph it, record anchor model and mount model for warranty claims if needed
How to remove a TV from brick later (no damage)​
If you ever need to remove:
Disconnect all cables
Lift TV off the mount bracket (reverse of installation)
Unbolt mount plate
Pull out anchors with pliers — they may leave small gaps in the brick
Patch with matching mortar: - Mix a small batch of mortar to match existing color - Fill the hole flush with the brick face - Let cure 24 hours - Color match can be improved with dry pigments if needed
Let cure 24 hours
Skilled masonry repair makes the old anchor locations virtually invisible. The brick itself is undamaged.
Common brick-mounting mistakes to avoid​
1. Using wrong drill​
A regular drill won't penetrate brick effectively. You'll overheat the drill and chip the brick surface. Use a hammer drill.
2. Drilling into mortar joints​
Mortar is much softer than brick — anchors pull out under load. Always drill into brick face.
3. Skipping silicone seals​
Water migrates through anchor holes into the wall cavity, causing long-term damage to insulation or framing behind.
4. Using indoor anchors outdoors​
Plain steel anchors rust within 12–18 months outdoors, staining the wall and weakening the install.
5. Over-tightening bolts​
Crushes brick around the anchor, reducing holding strength. Finger-tight plus 1/4 turn is enough.
6. Drilling in old or historic brick without load-testing​
Pre-1950s brick may crack under drilling. Test one anchor first before committing to the full pattern.
7. Hidden chimney or vent behind brick​
Some brick walls hide flues, vents, or electrical conduit. Check blueprints if available, or use an inspection camera if unsure.
Brick vs other wall types for outdoor TV​
Wall type​
Pros​
Cons​
Outdoor TV suitability​
Brick (solid)Strongest hold, patchable, rot-proofDrilling effort⭐⭐⭐⭐⭐ Best
Wood framing + sidingEasy drillingRot risk, stud hunting⭐⭐⭐⭐ Good
Concrete block (CMU)StrongRequires masonry bits⭐⭐⭐⭐ Good
Stucco over framingEasy drillingBrittle surface cracks⭐⭐⭐ OK
Brick veneer (thin)Nice aestheticLimited load, short anchors needed⭐⭐⭐ OK
Vinyl siding—Hollow, must find studs behind⭐⭐ Marginal
Brick is genuinely the best outdoor TV mounting surface — longest-lasting, most stable, most weatherproof.
FAQ​
Can I mount an outdoor TV on a brick fireplace?​
Yes — with caveats. Ensure:
Fireplace is rated for non-load-bearing mounting (most are)
TV is above the top of the flue's heat zone (check clearances in fireplace manual)
Use articulating mount to tilt screen down for seated viewers
Heat from chimney doesn't reach TV — check with infrared thermometer during fireplace use
How do I hide cables on a brick wall?​
Run through the wall (Option A above) for cleanest look
Surface conduit painted to match brick
Cable covers along wall edges
Routing cables along mortar joints and sealing with matching mortar fill
Do I need a permit to install an outdoor TV on brick?​
In most jurisdictions, no permit needed for the TV installation itself. However, if you're installing a new GFCI outdoor outlet, that typically requires an electrical permit.
What's the best brick-compatible TV mount?​
Any outdoor-rated VESA 400×400 mount. Popular brands: Echogear, Vivo, Sanus. Budget $120–$300 for a quality mount.
Will brick dust damage my TV during installation?​
Cover the TV with a cloth while drilling nearby. The dust itself is inert but can scratch the screen if not cleaned off before mounting.
Can I mount an outdoor TV on unpainted raw brick?​
Yes, perfectly fine. The brick's natural color may show anchor hole locations more visibly if the TV is ever removed. Paint touch-up is easier on painted brick.
Verdict​
Mounting an outdoor TV on brick is one of the most durable installation types — brick resists weather, holds weight reliably, and allows clean removal later. The 9-step process takes 2–4 hours with the right tools.
The **ByteFree BF-55ODTV** uses the universal VESA 400×400 pattern that works with virtually every outdoor-rated brick mount on the market. At 58 lbs, it falls comfortably within standard brick anchor load ratings.
→ Shop the ByteFree BF-55ODTV at bytefree.net — 55″ 4K, Dolby Vision + 30W Atmos, Google TV, IP55, 30-day return.
