Jaws on a 100-inch backyard screen is a harder ask than it sounds
SpaceXtt
Someone over on HTF is running Jaws in the backyard on a 100 inch screen this week for family and friends, which is a lovely idea and also one of the harder things you can attempt outdoors as a picture.
Jaws is mostly dark water. The night scenes, the Orca at anchor, everything happening under the boat, all of it lives at the bottom of the range. Outdoors you are fighting two things at once. Ambient light lifts your black floor until dark water turns into flat grey haze, and there is no ceiling or side walls bouncing anything back at you, so you lose the reflected energy that makes an indoor image feel brighter than it measures. What you end up with looks fine on the bright deck scenes and turns to mush exactly when the tension is supposed to land.
The fixes are all boring. Wait for genuine dark rather than dusk, kill every porch and path light in sightline of the screen including next door's, and run a smaller image than your throw allows. Ninety inches properly lit beats 110 inches of grey every time. Audio matters more than people expect too, because outdoors nothing reinforces the low end and the Williams score is doing a lot of work down there. One sub on the ground aimed at the seating helps more than another pair of satellites ever will.
The 1975 crowd watching it in a garden in 2026 is the part I actually like about this. Has anyone here done a proper outdoor night with a genuinely dark film and got it to hold, or did you give up and switch to something brighter halfway through?
mtn328
Every outdoor screening I have done ended up smaller and brighter than I planned and it was the right call every single time.
Kevin254
The neighbour's security light is the one nobody plans for. Mine is motion triggered and fires whenever someone gets up for a drink.
58129166
Sub on grass is its own problem. Mine sounded completely different on the lawn than it did sitting on the patio slab.
laxhockey11
At a garden party nobody is watching black level, they are talking. Pick something people can dip in and out of and save Jaws for indoors.
