LouiseWinner
McGee Hybrid-Amplifier Legend is equipped with a gallstone hybrid amplifier. It is compatible with multimedia functions, which is almost the same as a digital amplifier! In our usual impression, the timbre of gallstone amplifiers is warmer than that of digital amplifiers, and the sound will be much more audible.
McGee Hybrid-Amplifier Legend uses a very typical front bile and back stone design. Three JJ electronic bile ducts (two ECC82 and one ECC83S) are placed in front, and Toshiba transistors are built in the back. As a hybrid gallstone power amplifier, it can not only amplify the analog signal, but also has a built-in DAC and Bluetooth chip, so from a certain perspective, you can also use it as a digital power amplifier.
The front panel is mainly some commonly used buttons, such as input selection (switching USB/SD, Bluetooth, analog, digital mode), equal loudness adjustment, volume adjustment, mute button, lighting effects and headphone jack. It is also equipped with optical fiber, coaxial, USB, SD card sockets.
Hi-Fi for young people
The small Hi-Fi system McGee Hybrid-Amplifier Legend conforms to the consumption habits of modern people, and sacrifices the space to get a good music enjoyment. Secondly, the simple design and support for many input methods make Hi-Fi a device that can be played by the whole family.
McGee Hybrid-Amplifier Legend can increase the volume of high-frequency and low-frequency components at low volume, even if the sound is not loud, you can fully hear the mid-high and low-frequency details of the song. This feature effectively solves the biggest annoyance of installing a home Hi-Fi system - noise, users no longer have to worry about disturbing neighbors when playing concerts, and turning down the volume can also obtain the same sound effect at high volume.
In addition to enjoying digital music on the headset, you can also connect a digital player to the amplifier to experience Hi-Fi music. McGee Hybrid-Amplifier Legend can output music with a sampling rate of up to 192kHz/24bit, and supports playback of multiple audio format files such as WAV, FLAC, APE, and LPCM.
McGee Legend Speaker is equipped with a 1-inch tweeter and a 4-inch woofer. Compared with McGee McGee Hybrid-Amplifier Legend, its design can be said to be clear at a glance.
Bluetooth connection
The effect played by using the iPhone is not as ideal as I imagined. In the case of a large volume, the background music is even a little hoarse. Judging by the few popular music of the trial broadcast, I personally think that if you want to pursue a better sound effect, it is recommended to choose CD Or enter other high-standard music resources, McGee legend does not focus on wireless music transmission.
Switching to a CD player, the change in sound effects is particularly obvious, the clarity has been improved, the details have become richer. I personally like the resolution of the mid-frequency of this sound system. When listening to popular music, it is particularly attractive. The vocal quality is mellow. The sound is very comfortable and pleasant.
Because the amplifier has the "equal loudness adjustment" button, after it is turned on, the low-frequency and high-frequency volume-sensing ears can obviously hear some size changes. Its effect will not be too contrived, although the high frequency has a little bit of thorns, but it is also very bright, the low frequency amount feels a bit, the elasticity is clean and neat, and it is closely connected with the intermediate frequency. If it is not turned on, high frequency and low frequency will not look too deliberate, but have a sense of nature. I personally think that the sound effect under the "equal loudness adjustment" can be accepted regardless of whether it is turned on or off. Its biggest benefit is that it can help users have a good listening experience at low volume.
McGee Hybrid-Amplifier Legend basic specifications
Channel rated power: 2×80W
Frequency response: 20Hz-20kHz
Input impedance: 47KΩ
Signal to noise ratio: >90dB
Input sensitivity: 400MV
Audio output: subwoofer, 5-pin signal cable
Audio format: WAV, FLAC, APE, LPCM, MP3, AAC, AC3, WMA
Signal input: RCA, XWFL, Bluetooth, coaxial output, light digital input
Price: 699 euro
McGee Legend Speaker specifications:
Unit: 1 inch treble × 1, 4 inch bass × 1
Frequency response: 50Hz-20KHz±3dB
Sensitivity: 84dB
Rated impedance: 4Ω
Power load: 20-100W
Price: 249 euro
Price: 699 euro
Sensitivity: 84dB
Rated impedance: 4Ω
Power load: 20-100W
Price: 249 euro
