OLED, mini LED, RGB backlight: what you actually notice in your own room
Kevinlll
Strip the acronyms back and there are only two kinds of television being sold. OLED is emissive, meaning every pixel makes its own light, the way plasma and CRT did. Everything else - QLED, mini LED, RGB backlit, whatever the badge says this season - is an LCD panel with a backlight behind it, and the arguments are all about how cleverly that backlight is controlled. Once you hold that distinction in your head the marketing sorts itself out fairly quickly.
What that means in practice depends almost entirely on your room, which is the part the spec sheets never cover. OLED's advantage is black level and colour saturation, and it shows up in a dim or controlled room, at night, on films. Its historical weakness is peak brightness, which is exactly what bites in a bright living room with two windows behind the sofa. LCD backlights, mini LED and RGB variants included, go much brighter, and the cost is that no backlight system fully stops light leaking through a panel that is supposed to be showing black.
Then there is size, which quietly decides more purchases than any of this. LCD motherglass can be made bigger and cheaper than OLED motherglass, so OLED tops out at 97 inches and realistically stops at 77 or 83 for most buyers, while LCD keeps going well past that at prices people will actually pay.
So the honest version of the question isn't which technology wins. It's whether your room is dark enough for OLED's strengths to matter, and whether you want a size OLED doesn't sensibly make. Which one decided it for you?
Hsadas
Room first, panel second. Took me two returns to work that out. South facing lounge and an OLED was a permanent compromise.
Yusss777
Emissive versus transmissive is the only slide anyone needs. Everything after that is a backlight control argument with a new brand name attached.
Adney
Size is the real one. Wanted 85 inches, that ended the discussion before the picture quality debate even started.
PLAY GAME
Bright room mini LED still beats OLED for daytime sport in my house. At night it is not close the other way.
