Phone and tablet as outdoor cinema - 3000 nits helps, 6.3 inches does not
Gorher
What Hi-Fi put together a portable viewing list for summer, and the two setups worth arguing about are an iPhone 17 with AirPods Max 2, and a Galaxy Tab S11 Ultra with Buds 4 Pro. Sensible picks in isolation. As an outdoor answer they hit the same wall everything portable hits.
The brightness figures actually make their case. The iPhone is quoted at 3000 nits peak with Dolby Vision, HDR10+, HDR10 and HLG support, which is more than most living room sets will ever put on screen, and the Tab S11 Ultra runs 1600 nits on a 14.6-inch AMOLED with an anti-reflective screen. Outdoors, nits and reflection handling matter far more than resolution, and both are respectable in direct sun.
The problem is angular size. A 6.3-inch phone at arm's length fills less of your vision than a 55-inch set across a normal room, and a 14.6-inch tablet is not much better the moment anyone else wants in. Which is the real limitation here: these are single-viewer solutions. Two of you on the patio and the tablet turns into a thing you both crane at, while the head-tracked spatial audio stops being clever because only one person is wearing the buds.
That is exactly why outdoor screens and portable projectors keep existing despite being more hassle to set up. Group viewing is the entire point of watching outside. Everything else is watching alone in a nicer chair.
Battery is the one place the portable route genuinely wins. The tablet is quoted as getting well into a second day of viewing, and the buds at 26 hours with noise cancelling on, counting the case.
So what do people here actually use in the garden after dark, and how many of you are watching alone?
Anna
3000 nits on a phone is wasted anywhere except direct sun, and in direct sun you cannot see the bud controls anyway. Everything outdoors is a trade.
Ok_Camel
The anti-reflective screen on the Samsung is underrated. Matters more outside than any brightness figure once the sun sits off to one side.
