I see they're basically the same, except, LG 55UH651Y has 2 USB ports, while Samsung UE65AU7192 has only one.Thanks for all the information!
* today i am using this TV- LG 55UH651Y , and I am looking to replace it (not because its not good) but just for the reason that I need it in another room.
* so I will use the Samsung in the living room (main TV) ,
and the LG in a secondary room
so my question is: LG 55UH651Y VS Samsung UE65AU7192
will I notice any difference between them? apart from the size..
Please let us know how it goes when you receive iteventually I decided not to buy it..
I bought XIAOMI L65M5-5ASP. they are the same price +- and I heard good reviews about this model..
2019 model, right?eventually I decided not to buy it..
I willPlease let us know how it goes when you receive it
not exactly sure, 2019 / 2020..2019 model, right?
Xiaomi TV box is pretty goodI will
How about this tv? is it good?eventually I decided not to buy it..
I am very satisfied from it.How about this tv? is it good?
That's cool, btw, you can try to install a Emotn Store on your tv, then you can install all kinds of app. I found it good recentlyI am very satisfied from it.
the big + is the "pure android" and I can use any app from playstore..
No problemI will try it.. Thanks!
