AustinJ 7921354wk2
With the development of projector technology, intelligent projector has gradually appeared, and in recent years is quite hot, but the projector has not been able to develop at the same speed as the mobile phone, and it is still far behind in configuration, so there is often a situation of Caton in the use of the projector, especially when playing video. So what should I do? Here are a few things that will help you solve the problem of projector jam.
Reason 1: low configuration
At present, most of the processing chips on the projector are 28nm process, and the better is 14nm process. Compared with the mobile phone, the processing performance is incomparable. Moreover, many memory combinations are 1 + 8GB, 1 + 16GB, 2 + 8 or 2 + 16GB in memory. It is inevitable that the projector will be stuck for a long time.
Solution: restore the factory settings or delete the infrequently used TV software to maintain a large memory space; if you haven't started the projector, you'd better buy a projector with a high configuration, such as Dangbei F1 etc.
Reason 2: poor system
The projector system is mostly similar to many intelligent TV operating systems. Many projector manufacturers have their own operating systems, but they are similar in design style. They all adopt the up-down distributed design, with a lot of content distributed up and down, left and right. Some systems also have many pop ups, advertisements and other redundant functions. Because more loads are needed to start up, there are more added to the app Load, so it will also lead to the Caton phenomenon.
Solution: brush the projector and find a simpler operating system. You can use the external intelligent TV box, such as the high-performance Dangbei TV Box, hermetic, etc.
Reason 3: motion compensation
For some projectors supporting motion compensation, some projectors have motion compensation function. Motion compensation will increase the frame number of the picture to improve the smoothness of the picture and reduce the phenomenon of dragging. However, if not properly used, it will also cause the picture of the projector to jam. Some films and TV pictures with appropriate frame number do not need to turn on motion compensation. If they are turned on or the frame number is too high, they will get stuck.
Solution: the most suitable number of frames for motion compensation debugging.
