Wemax Smart Portable Projector M055FCN is better than Xgimi Halo
EmmaStone
How is Wemax Smart Projector M055FCN? This video projector comes in a cubic form of modest dimensions (155 by 125 by 160mm) and a verified weight of 2.62 kg which will allow Wemax Smart Projector M055FCN to travel easily in a photo bag. It is easily transportable from one room to another, thanks to a handle (leather?) on Wemax Smart Projector M055FCN
Wemax Smart DMD M055FCN
At the outputs of Wemax Smart Projector M055FCN's black case, the device is supplied with a black Bluetooth remote control, sober and efficient (batteries included!), Its power supply (provide an adapter for our regions), as well as its brief instructions and its warranty (a suede is provided to clean the sealed protection of the optics.)
Wemax Smart Projector M055FCN is of a construction and finish without reproach makes it a beautiful model. Its 6mm thread allows easy installation of a tripod. This portable Wemax Smart Projector M055FCN has an integrated battery of 16000 mah which during my tests, will have held a little less than 2 hours in standard light mode, which is a good performance. To take advantage of its all-in-one side, it is equipped with 2X5W amplified speakers which deliver an astonishing sound with regard to their dimensions.
Wemax Smart Projector M055FCN is DLP technology (DMD chip 0.33 with 1080p resolution by XPR processing) with LED light source of 550 ANSI lumens (lifespan of more than 30,000 hours), it is 3D compatible (untested) and supports 4K signals HDR. Its fixed focal length has a throw ratio of 1.2: 1
For owners of video projectors with MiTV, you will be like me at ease with this overlay of Android, which brings its share of technical solutions such as DLNA management, Airplay and Miracast. We will take advantage of its excellent media player, but also keyboard shortcuts to access the various settings of the device during playback. (display, fast focus, keystone, 3D ..)
APK applications such as Netflix, Molotov, Youtube, Plex, you will use the next " " SMART TV "of WEmax. If this environment is hostile to you, it is possible to add a Fire stick type key to it and ask the projector to boot on it at startup.
Wemax Smart DMD M055FCN menu
The speakers that equip this laptop give a rather impressive sound rendering during the playback of a movie, (a little less in stereo listening), with a sound at the same time powerful, detailed, dynamic, clear voices and effects " surround Convincing. This is good because it benefits from DTS HD and DOLBY ATMOS certifications.
It is equipped with Bluetooth low latency two-way and can therefore be used as an additional speaker via your smartphone, or send the sound stream to an amplifier or sound bar compatible with BT. The latter is very well managed, (I did not feel any sound-image lag whatsoever with my AirPods or my fda SMSL amplifier.) The Wemax Smart has reduced connectivity but sufficient for mobile use: 1 HDMI, 1 USB 3.0, 1 mains connector and a 3.5mm cinch headphone output without faults.
It does not have an Ethernet socket but a simple accessory connected to its USB socket solves the problem. Its HDMI socket is not ARC compatible.
Wemax Smart DMD M055FCN connectors
It's crazy how Wemax Smart Projector M055FCN becomes endearing, they are aesthetically successful, their built-in battery, their sound system of (very) good quality for the Wemax and their " SMART TV " rating often lead us to move them around and get our hands. ' Wow ' effect of a large image, and this on any type of support.
This is the case with this Wemax Smart Projector M055FCN which will have wandered through several rooms of the house including the terrace, to finally stay a few hours in my room on a white canvas.
The image thus delivered gratified us with beautiful colors, with a satisfactory brightness and contrast with the bonus of 4K HDR images processed in much better ways than the Xgimi Halo , provided that we remain reasonable in projection size.
Image Wemax Smart DMD M055FCN
It lacks, in SDR, compared to its competitor, its sharpness, its precision as well as its brightness for screen bases greater than 2m
The sound when it is really breathtaking, a pity that the noise of the fans tarnish (a little) the picture during calm scenes (measured at 36db against 29db for the XGIMI Halo ).
If its positioning is not exactly in the axis, an excellent 4-point keystone correction is available. Despite the absence of a compensation motor, the Wemax remains fluid.
In conclusion
This Wemax Smart Projector M055FCN shows once again that video projection is about to democratize with these portable models all in one and relatively accessible (The Wemax Smart Projector M055FCN is available around $ 600). Able to deliver a beautiful and big image in a rewarding case, with a sound worthy of a good Bluetooth speaker, all at a contained price, it deserves your attention.
Wemax Smart Projector M055FCN pros :
  • Its look,
  • Its brightness (for a traveller),
  • Its image on any type of support and its adjustment possibilities,
  • Sound rendering in film mode,
  • Battery life,
  • Its placement facilitated with a mini tripod.
Wemax Smart Projector M055FCN cons,which it should do better :
  • Better contained ventilation noise,
  • An image with more sharpness and sharpness,
  • An HDMI arc 3.
