Thick_Weight6037
Bouncing a projector off a 45 degree mirror into the back of a rear-projection screen works, but the mirror is where it succeeds or fails, not the projector. Use a first-surface mirror. A normal household mirror reflects once off the front of the glass and again off the silvering behind it, and over a metre of folded path that second reflection is a ghost image sitting beside every bright edge in the picture.
The other thing to settle before spending anything is whether a UST is even the right lens for this. The target image is 100cm wide, which is small, and USTs are built around one very specific relationship between lens and surface. Most have a minimum size they will focus at, and it is often larger than people assume. The mirror bounce also puts its own path length back into the sum, so the folded distance can easily land inside what an ordinary short-throw is asking for. That opens up a lot more choice at 1000 to 1200 dollars.
Rear-projection screen material is a separate purchase and not optional, and the image needs flipping, which every projector I have owned handles in the menu under rear or ceiling modes.
Measure the real optical path along the folded line rather than the depth of the cabinet, and hold that number against the throw table of whatever you are considering. That comparison settles this before any money moves.
