Best QLED lists keep recommending mini-LED sets - the label is now noise
Read another best QLED TVs for 2026 roundup this week and the top pick was Sony's Bravia 9, whose own spec box in the same article lists the display type as mini-LED. That is not a mistake on the writer's part so much as a symptom. QLED stopped describing anything specific years ago and nobody has replaced it with a word that works.
Here is the actual split, and it matters when you shop. Quantum dots are a colour layer. Mini-LED is a backlight, thousands of small LEDs in a lot of dimming zones. They are separate axes. A set can have quantum dots and a dozen edge-lit zones and it will still say QLED on the box. Another can have quantum dots and two thousand mini-LED zones. Same three letters, completely different picture in a dark room. The buyer with a $700 budget and the buyer with a $3,000 budget are reading the same badge and getting told the same thing by it.
The roundups compound it because they file everything with a quantum dot layer under QLED, then the useful information ends up buried in the cons. That same article's picks lean on peak brightness and anti-reflective coatings on the value sets and warn about off-angle falloff and muted colour next to OLED - which is a way of describing the panel type, not the badge.
If you are shopping, ignore QLED as a filter and ask two questions instead. How many dimming zones, and is it VA or IPS. Those two answers predict what you will actually see far better than the marketing name does.
Has anyone found a retailer that publishes zone counts, or is it still down to reviewers pulling them out with a test pattern?
