Dangbei C2 Projector Review: Light and Portable Mini Projector
Elena
Dangbei Projector C2 is portable, compact with 3-hour battery life and fully automatic laser focus and very cost-effective.
Here’s the review of this portable mini projector.
Dangbei C2 Mini Projector
ModelDangbei C2
MaterialPC + ABS VO level fireproof plastic material
Size of the Projection30-300 inches (recommended 40 to 60 inches
Brightness255 ANSI lumens
resolution848x480dpi (480P)
The projection light sourceOsram LED light source
DLP0.2"DMD
The processorMstar 6A358
Memory and Storage1GB+16GB(storage support for 1T)
Zoom/focusFixed focus/sensorless auto-focus
The projection ratio1.2:1
Size/gross weight82x87x141 mm /0.72 kg
interfaceUSB 2.0 * 1
HDMI interface HDMI * 1 (ARC)
Audio interface 35 mm * 1
DC jack * 1
In appearance, Dangbei C2 small projector is still square shape, the body is made of PC+ABS V0 fireproof plastic material.
However, the line cutting is more rounded than the previous C1, which is specifically shown in the upper and lower borders with radian transition. The edges and corners are very rounded and smooth without cutting hands after processing.
Color matching also from pure black to some lively black and white panda color matching, color collision design is bound to more fit the aesthetic preferences of young people.
Shorter than the iPhone XR
This is the second portable projector from Dangbei, and it has an increasingly improved grip. It can be moved around with one hand or put in a bag on business trips. 82x87x141mm it doesn't take up much space, probably takes up less space than your vaccum cup, and the body weight is only 720 grams, take it out is equivalent to an extra bottle of mineral water.
There are one large len and one small len, the main lens adopts the full glass material prime lens, long time use is not virtual focus. The small one has a built-in ToF sensor. Combined with the changes in the machine position captured by the gravity sensor, the perceptionless focus can be achieved when the machine is lowered to see a clear picture.
According to Dangbei officials, focusing with the ToF sensor is more than 10 times more efficient than focusing with a traditional camera. With the trapezoidal correction function, arbitrary display of the screen can be square is the heart to see.
There's also a battery alert light on the top. In terms of battery life, we tested it out, and the 9,600 mah battery gave us about three hours of battery life.
The iconic grille design on the side of the body features a large thermal grille and a fan that actively dissipates heat.
USB 2.0*1+HDMI port HDMI*1 (support ARC) + audio port 3.5mm*1+DC socket *1
Threaded port to support bracket mounting
Dangbei C2 Projector Remote
The remote control is great, with a magic side key on the side that long presses to trigger quick focus. In addition, the daily triggering of AI intelligent voice remote control is also by pressing the corresponding keys on the remote control.
Elena
Processor platform
Whether it is a normal large home projector or a portable mini projector, the processor has always been the most important core technology to determine the power of a product. It decided to include picture quality, speed, and the ability to parse 4K video sources on a chip powerful enough to make it easy for devices to use.
Dangbei C2 Projector is powered by the Mstar 6A358, a TV chip commonly used in entry-level smart TVS. The core specifications are not available, currently only known that it supports dual 8/10 bit LVDS output, support OpenGL ES 1.1/2.0 and OpenVG 1.1, support 1920×1080@60Hz decoding
Elena
Viewing Experience
The solution chosen for Dangbei C2 is the Osram high power LED lamp set with 255ANSI lumen brightness and HDR10 high dynamic decoding. The actual ANSI brightness of most mini projectors is only 100~200ANSI lumens, or even less than 100 ANSI lumens.
This is not a low level of brightness for a mini projector, which is limited by its size to use more powerful lighting sources and multi-DLP projection schemes. At the same time, Dangbei C2 uses a 0.2DMD display chip with a resolution of 480P.
From practical use, the brightness of Dangbei C2 is quite high when the projection screen is within 30 inches, and no affection even if the indoor direct lighting. We recommend a 30 - to 40-inch projection for both brightness and frame size
Next, under a 30-inch projection screen, we compared the performance of Dangbei C2 by a set of real time tests with the lights off and on (close indoor light exposure).
light off
light on
light off
light on
Elena
Summary
Compared with the semi-fixed or fixed installation of household projectors, Dangbei C2 projector eliminates the installation link, there is no requirement for installation and display scene. It has a battery, a side port, and you can toss it on your couch, on the ceiling, on any white wall, or even on a flat surface.
Dangbei C2 projector comes with 9600mAh battery, the battery life is relatively sufficient, energy saving mode can support about 2 hours and 30 minutes of video playing battery life, when going out can be competent for short and medium distance travel on the road, completely get rid of the cable.
In addition, there are a lot of bonus points on Dangbei C2, such as TOF laser autofocus, because the portable projector is often moved, there is a fast autofocus function so that we do not need to manually adjust again and again, and the upper and lower automatic trapezoidal correction function saves a lot of trouble.
