Mobile Sharing under Android is troublesome. The system itself cannot recognize the NTFS / EXT3 / 4 hard disk with data. It needs to be emptied and then mounted. It is too troublesome to transfer data to the hard disk of 1T hard drive. It is too troublesome to recommend that you install CE. CE comes with SAMBA / DLNA / NFS sharing.
Of course, even if the TF card is installed with CE, the Android program cannot be used when the CE is running. It needs to be restarted. This method is not suitable for people who use Android apps.
