LG TV 55SM8600PUA Nano 8 Series Review
AssasinK
LG TV is overall good. I trust this brand. Here I want to share with you the LG TV 55SM8600PUA Nano 8 Series pros and cons. If you take this TV into consideration, read the following review.
LG TV 55SM8600PUA Nano 8 Series Specifications:
Dimensions: W/ Stand 48.5"W x 30.9"H x 10.4"D | W/o Stand 48.5"W x 28.2"H x 2.5"D | Stand Width 33.1"
Item Weight: 41.20 lbs
Display Type: LED
Resolution: 4K
Voice assistant: Google Assistant and Alexa
Connectivity: HDMI, Bluetooth, Ethernet, Wireless, USB
Work with Airplay 2
Ports: 4 HDMI
Refresh Rate: 120 Hz
Model Year: 2019
Price: $744
LG TV 55SM8600PUA Nano 8 Series Pros:
1. Good picture quality.
2. The remote control has a scroll wheel which allows you to mouse around on the screen.
3. Apps work smoothly. Sound leaves a little something to be desired but if you're serious about sound quality youve probably got a sound bar or something anyway.
4. Enjoy easy access and control of apps such as netflix, prime video.
5. Set up is simple.
LG TV 55SM8600PUA Nano 8 Series Cons:
1. The sound pairs easily with bluetooth speakers but requires that you reconnect every time to start the TV.
2. Alexa ONLY works from the microphone button on the remote.
3. Choice of Android apps is limited.
