loughborough
Today VESA DisplayPort Alt released the 2.0 model, for future USB4 device supports DisplayPort 2.0 paved the way.
DisplayPort 2.0 was released in June 2019, with a maximum effective bandwidth of 77.4 Gbps, almost three times that of DisplayPort 1.4. The new standard supports up to 16K resolution display output , higher refresh rate, higher resolution HDR support, and improved support for multiple display configurations. DisplayPort Alt Mode 2.0 provides seamless interoperability with the USB4 specification released by the USB Implementers Forum (USB-if), and fully supports all functions in the latest version of the DisplayPort standard (version 2.0) through the USB Type-C connector . In DisplayPort Alt mode, up to 80Gbps of video data can be transmitted through all 4 high-speed channels in the USB-C cable.
Currently, there is no projector using usb4.0 port, the majority of PJ producers provide 2.0 version. However, some powerdul models already supported usb3.0-such as Dangbei flagship Prohector F3/F1. Dangbei F3 has fitted a pair of HDMI ports and two for USB (two 3.0) to access content from an external hard drive or USB stick. There is also an Ethernet connection for wired internet, which we’d always recommend using for greatest speeds and bandwidth when streaming from online.
see more related information of Dangbei F3
for more projector information & knowledge, you can come to https://www.tvsbook.com/forums/projector.5/
