Running the same feed to a projector room and a CX in the next room
goalweiser
Came across a basement build that has the part I keep putting off: an 11x14 room with the projector, and an overflow room right outside the doors with a sectional for eight and an LG CX with a soundbar. Both rooms get fed off an HDMI splitter so everyone is watching the same thing for the Super Bowl or a big family night. Nice idea, and also the exact spot where these setups usually go sideways.
It comes down to EDID. A splitter has to report one set of display capabilities back to the source, and whatever it reports is what both rooms are stuck with. Auto-copy modes tend to grab whichever display answers first, or fall back to the lowest common denominator across both outputs, and then you find out the projector is capped because something else in the chain only claims 1080p. Most decent splitters let you lock EDID to a fixed profile or to one specific output, and that setting is worth finding before you start blaming the source device.
The other thing is that a CX and a projector will never look like the same picture, which does not matter at all for football and matters quite a lot if someone in the overflow room is watching a film and comparing. And with the doors open you have two audio paths with different latency, so the overflow room cheers a beat behind the main room. Not fatal, just funny the first time it happens.
For anyone running a second room off a splitter: did you end up locking EDID to the main display, or did auto-copy actually behave itself?
Mia
Locked mine to the projector output and never touched it again. Auto-copy kept renegotiating every time the soundbar in the other room powered down, which killed the picture in the main room mid-film.
Emma
The latency thing is real. Ours is about a second apart and during a game you hear the other room react first, so you know a goal is coming before you see it. Ruins any tension.
Ok_Camel
11x14 for the main room and eight seats in the overflow, that ratio says a lot about who actually uses the theater 😄
Nadia
Which splitter though? Brand matters more than the spec sheet here. I went through two cheap ones before buying a proper one with EDID banks and manual HDCP selection.
JimmyBox
Worth adding that some splitters downgrade HDCP to 1.4 across both outputs, so your 4K sources drop resolution without telling you. Check that before assuming EDID is the culprit.
