Mialulu
OnePlus has launched two 43 inch TV called Y1s and Y1s Edge, what's the difference between them? Actually, here is a comparison chart of OnePlus TV 43 Y1S vs Y1s Edge, and almost found that they are the same. Let's have a look.
From the comparison chart we can see that there is a difference, the OnePlus Y1s doesn't support TÜV Rheinland Certification while OnePlus Y1s Edge does, which mean that OnePlus Y1s Edge is a safe product that has been investigated to particular safety requirements by an accredited third party and is supported by regular surveillance audits and factory inspections.
Both the OnePlus Y1S and Y1s Edge TV feature a Gamma Engine, which intelligently adjusts the picture for ultra-sharp content. It allows users to experience bolder dynamic contrasts and vibrant colors for easy immersive viewing.
What's more, the OnePlus Y1S and Y1s Edge TV support the most popular mainstream high-dynamic-range formats: HDR10+, HDR10, and HLG. Transform your vision with a brighter, sharper image full of depth and vivid details.
Also, the OnePlus Y1S and Y1s Edge TV have powerful speakers deliver up to 24W of razor-sharp, high-definition audio that moves you1. From movies to sports, powerful and atmospheric sound takes your viewing to new heights.
Surely, the OnePlus Y1S and Y1s Edge TV have enough connection forts for sharing your content smarter with OnePlus Connect 2.04. With an intuitive design, managing and accessing your content has never been easier. OnePlus Connect 2.0 can now be used even without Wi-Fi or a data connection5.
| Specifications | TV 43 Y1S | TV 43 Y1S Edge |
| Resolution | 1920 x 1080 | 1920 x 1080 |
| HDR Compatibility | HDR10+ Decoding, HDR10, HLG | HDR10+ Decoding, HDR10, HLG |
| TÜV Rheinland Certification | NO | YES |
| Sound Output | 20W | Max 24W |
| Dolby Audio Format | Dolby Audio | Dolby Audio |
| Operating System | Android TV 11 | Android TV 11 |
| Application | OxygenPlay, Prime Video, Netflix, YouTube, Hotstar, Google Play Store, Bluetooth Stereo, Smart Manager etc. | OxygenPlay, Prime Video, Netflix, YouTube, Hotstar, Google Play Store, Bluetooth Stereo, Smart Manager etc. |
| Voice Assistant | Google Assistant built- in; Works with Alexa | Google Assistant built- in; Works with Alexa |
| Casting | Chromecast built-in, DLNA, Miracast | Chromecast built-in, DLNA, Miracast |
| Storage | 1GB+8GB | 1GB+8GB |
| Wi-Fi Standard | 2.4 GHz/5 GHz 802.11 a/b/g/n | 2.4 GHz/5 GHz 802.11 a/b/g/n |
| Bluetooth | 5.0 | 5.0 |
| Ethernet Input | 1, RJ45 | 1, RJ45 |
| RF Connection Input | 1 (DVB-T2,ATV) | 1 (DVB-T2,ATV) |
| HDMI Input | HDMI 2.0*2 (HDMI 1 with ARC) | HDMI 2.0*2 (HDMI 1 with ARC) |
| AV Input(Composite) | 1 (Mini 3 in 1) | 1 (Mini 3 in 1) |
| Digital Audio Output | Digital Audio Output | Digital Audio Output |
| USB Port | USB 2.0*2 | USB 2.0*2 |
| Smart Phone Connect | OnePlus Connect 2.0 | OnePlus Connect 2.0 |
| OnePlus Connect 2.0 | 1N Remote, 1N Power Cord, 1N User's Manual, 1N Warranty Card, 2N Stand Base, 2N Battery 1N AV In Adapter | 1N Remote, 1N Power Cord, 1N User's Manual, 1N Warranty Card, 2N Stand Base, 2N Battery 1N AV In Adapter |
